i need help asap....... trans/clutch problems
linz90
Post by linz90 »
i have adjusted the clutch and now it wont even release the clutch. ive done everything i could think of any ideas what it could be??
Post by entirelyturbo »
We need WAY more information.
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
linz90
Post by linz90 »
the only problem is when im at a standstill i can drive just fine shifting with the clutch smoothly but when im at a stop it wont even come out of gear unless the car is off like im being locked out
SLODRIVE
Post by SLODRIVE »
More info please...Cable or hydraulic clutch? You said you tried everything you could think of, please tell us what all that was. It'll be a LOT easier to help you out if ya tell us :-)
http://www.slodriveracing.com
-And more!
linz90
Post by linz90 »
its cable clutch and ive tried adjusting it tightening and loosening the cable no matter what i did it got worse like i have to yank it out of gear while its running
linz90
Post by linz90 »
i should have said this in the beginning that im a newb and am new to subarus ive done alot of work on toyotas and chevys.
Soul Shinobi
Post by Soul Shinobi »
You could have broken the cable or cause it to bind up if you twisted it. If you messed with your clutch pedal height or you've got a floor mat that could also cause the issue.
-Nick
1992 BC Legacy L Sedan AWD 5MT 272,000 - Wish you the best
1998 BK Legacy L Wagon 5MT 234,000 miles - RIP
2002 SF Forester S Wagon 5MT 215,000 miles - Current winter sleigh
1986 FC Mazda RX-7 GXL Coupe 5MT 155,000 miles - Summer cruiser
