auto to auto swap questions
subytech
Post by subytech »
Ok so we have a 94 AWD wagon with 3.90's that needs a trans, we picked up a 4AT from the junk yard from a 96 AWD impreza, I can't find a reliable sorce as to what the final drive for the impreza is. I think they are 4.11's. and if they are can we just swap a 4.11 rear end into the legacy or will it set trans codes? AND if it does set trans codes will the impreza TCU work in the leg? we just want to get the car reliable. Any help would be great.
92 Legacy Turbo, 5sp MT, Early Large CC 20G heads, Ported custom clocked td04, Cobb catted DP, Injen SS 3" exhaust, Turbosmart MBC @ 10psi, Apexi 20g intake, custom FMIC, Fidanza 11lb flywheel, stock 05 WRX clutch
BSOD2600
Post by BSOD2600 »
'11 WRX Limited
'94 TW | R.I.P.
