Hello,
I have a quick one this morning. Does the EJ22T out of a 91 SS use the 6/7 ignition system or the 36-2-2-2 system?
What type of ignition system on EJ22T
Can you elaborate what you mean by 6/7 & 36-2-2-2 ignition system?
SLODRIVE
I'm pretty sure it's 6/7 (6 reluctor teeth on the crank sprocket, 7 on the cam sprocket).
Is that whatcha mean?
http://www.slodriveracing.com
-And more!
-And more!
SLODRIVE wrote:I'm pretty sure it's 6/7 (6 reluctor teeth on the crank sprocket, 7 on the cam sprocket).
Yeah that's correct. I checked the factory manuals.
