'04 Sti BBS wheels, Fitment??
Slow Hatch
Post by Slow Hatch »
Got a chance to pick up some silver '04 Sti bbs wheels. I've seen a couple pictures with them on our cars. Will I need to run spacers to clear the stock suspension??
Slow Hatch
BTW Tire size would be helpful, lol. 225/45/17 Thanks
DLC
Post by DLC »
They should fit, but you'd probably have issues with fenders rubbing, not suspension.
Legacy Central
Slow Hatch
DLC wrote:They should fit, but you'd probably have issues with fenders rubbing, not suspension.
Ok, just figured since they were a high offset. 7.5 wide with a +53. I'm getting them today, so i guess we'll find out.
Slow Hatch
Welp, pick em' up today. And I was right. They fit fine in the fenders, but rub the rear struts. Need some spacers
Bdub
Post by Bdub »
I tried the spacers, and it still didn't resolve my rubbing issue on the bottom portion of the strut. I actually had to go with a 50 series tire to fix my issue. Although, I was using a 16" RS wheel, not really sure if you can get a 50 series tire in 17.
Through The Generations...
91 SS 4eat
95 LSi 4eat- Sold
07 2.5i 5mt- For Sale
13 STI Sedan
jton
Post by jton »
Yeah, spacers will help you out. And if you're lowered, may notice the negative camber a bit more with bigger wheels and tires. Rear camber bolts will help you there as well.
-Jimmy
[url=http://www.rs25.com/forums/showthread.php?t=104357]1993 Impreza L[/url] w/ Stroked EJ22T
EJ20G DOHC Heads
VF39
