WTB MAF electrical connector
Buffman
Post by Buffman »
Anyone got one they can part with for cheap. I discovered on the harness side of the connector, that the little blue wire has a break in insulation and corrosion has set in. This is a 2.2L N/A AT Wagon BTW. Dirt Cheap and in good shape preferred :) Need about 4-5" of tail :)
1992 Legacy LS Special Wagon..
Buffman
Post by Buffman »
I guess nevermind. Apparently the blue wire isn't used on my MAF (took cover off and there's no pin soldered to it)
