2002 outback 2.5 4eat?
Post by SubaruNation »
I just came across a 2002 outback 2.5 4eat for very cheap, and as teh tranny on my tw is dead.. im wondering if this tranny will be able to fit/work in my turbo wagon.
as far as i know, it should as long as the rear diffs match up correct?
thanks
Airgne
Post by Airgne »
it the diffs work it will be ok. i beleive you will have to get the TCU for the tranny as well.
1997 Nissan Laurel ClubS25t
1992 Legacy SS(Sold)
bump for braaaiiinnnnz :D
more info if anyone has any?
fishbone79
Post by fishbone79 »
Is the bell housing fitment the same on that? Is that before they switched to a different style for the 2.5?
Parenthetically, does anyone know when exactly that switch was? I'd love to put in a nice new transmission with higher road gears.
Cheers,
morgan
1992 Legacy BF
the one im looking to buy looks like this:
fishbone79
It's a bit different, but it might work if the necessary holes are correctly aligned... Here's the first gen layout (obv. off an NA): Image
The pic is off ebay, link will die in a few days... sorry.
Cheers,
morgan
1992 Legacy BF
n2x4
Post by n2x4 »
There's always been a big question of whether a late model automatic will work in the Legacy. Will it fit? Yes. The torque converter will bolt to the flex plate, and the bell housing will mate to any EJ engine.
Anything older than a 98 should work as it's still phase 1. Newer than that is up in the air, as no one's really sure what changed in the electronics. Are the transmission plugs the same? Are the pinouts the same? That kind of stuff.
There are a few older threads here on the boards that discuss it but nothing that ever came to a definitive conclusion. I think Josh knows the most about this but it's all been posted before.
You should try it and let us know if it works!
SUBARUEHS Racing
wtdash
Post by wtdash »
Electronics are different, even if the plugs are the same..which I doubt.
Over on the USMB this has been covered
(which is my source for this info....not from personal experience.)
Good luck,
TD
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
fishbone79
Thats my main question, will the newer (post 98 ) bellhousing bolt up to the older EJ engines? It doesn't look like the bolt pattern/layout is the same. I did a few searches here but they were fairly inconclusive… no definitive answer on the mate-up.
I'm mainly wondering about the MT; he's interested in the AT, but they should be the same, no?
Cheers,
morgan
1992 Legacy BF
n2x4
Post by n2x4 »
fishbone79 wrote:Thats my main question, will the newer (post 98 ) bellhousing bolt up to the older EJ engines?
Yes, it will bolt up. Phase 1 had 4 mounting locations, Phase 2 used the original 4 locations, plus 2 or 4 more (I can't remember).
Also, the phase 1 lower starter mount was a stud with a 17mm nut. phase 2 was a bolt that went into the block.
Todd, any links to the threads on USMB? I really need to start reading that forum more....
SUBARUEHS Racing
wtdash
Post by wtdash »
n2x4 wrote:....
Sorry, nothing bookmarked/saved...I'd have to Search it too. I've just stumbled across threads in the past.
Td
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
the gearing on the outback is 4.44
is that going to be an issue also?
wtdash
Post by wtdash »
SubaruNation wrote:the gearing on the outback is 4.44
Yes, your TW is 3.9 - if stock.
Td
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
so the rear diffs will not be compatible?
do i need a rear diff out of the same model year outback??
wtdash
Post by wtdash »
SubaruNation wrote:so the rear diffs will not be compatible?
Correct.
Probably not same year, but most likely same generation, plus the axles (stubs) may be different.
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
The electronics are by no means compatible. It will bolt up, but you will be stuck in third gear permanently. Unless you get a matching TCU and do the wiring, forget about it.
wowee.
well thank you guys very much for the heads up,
glad i found this out. :)
one final question if you guys (anyone) wouldn't mind.
the Tranny in my TW is dead, and i am wondering if i can throw a transmission out of a N/A automatic (4eat) of the similar years (92-94) in it with no problem.
Thanks alot
wtdash
Post by wtdash »
Yes, the tranny will work - same diff ratio 3.9. You'll also want the TC, flexplate, and starter from the NA, I believe.
I haven't confirmed whether an NA TC/flexplate works w/a turbo tranny.
I DO know the TC and Flexplate must match.
GL,
TD
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
