Jdm 4 piston brakes
sleepinsuby
Jdm 4 piston brakes
Post by sleepinsuby »
I have a 94 ss that I purchased recently that came with 4 piston front calipers.. they are jdm. I have spent the last two weeks searching the net, and buying and takin back usdm brake pads trying to find ones that fit. Anyway Im tryin to figure out what jdm cars came with 4 piston calipers that will bolt on to our cars. I think it is the jdm legacy or the jdm Impreza. Or can anyone positively identify the calipers I've got? I've tried pads from 06 Wrx and 06 sti pads. They're similar to the sti pads but for a smaller rotor. I can take a picture if you need. Any help would be greatly appreciated. thanks
PhyrraM
Post by PhyrraM »
Have you tried '90-'95 300Z twin turbo pads? I seem to recall a few post that indicate they may be the same as the JDM 4pots.
Failing that maybe you can try trading them to a "JDM whore fanboi" for a set of '06-'07 WRX 4 pots?
I'm sure some of the established Subaru shops can source the proper pads also. I would search/ask on rs25 or Nasioc.
They should be the same as '06-'07 WRX calipers. How did they not fit? Pics would help.
93forestpearl wrote:They should be the same as '06-'07 WRX calipers. How did they not fit? Pics would help.
Ditto.
Airgne
Post by Airgne »
the link below is were i got my brakes from. i have pdm 4 pots and usdm 2 pots.
4 pot pad part number for EBC red stuff is DP31200c
2pot pad part number for EBC red stuff is
dp2826c
it will say for a nissan 300zx but they are the same caliper. made by the same company.
front rotor part number for EBC is
GD972
rear rotor part number for EBC is
GD7409
http://www.placeforbrakes.com/index.php
hope this helps. i jsut did this last week.
1997 Nissan Laurel ClubS25t
1992 Legacy SS(Sold)
jamal
Vendor
Vendor
Post by jamal »
the D-plate numbers are also in the brake sticky.
Pad-wise they might be the same, but they are not the same caliper. The main caliper body is the same, but the "ears" for mounting are not in the same spot. There is about a 1/4" difference.
Airgne
Post by Airgne »
93forestpearl wrote:Pad-wise they might be the same, but they are not the same caliper. The main caliper body is the same, but the "ears" for mounting are not in the same spot. There is about a 1/4" difference.
sorry i didnt say everything about the damn calipers, but he has the FHI calipers so i didnt think it would have to be said. :smt019
they are the same cailper made by the same company. you have to get adapters because the nissan rotors are 5mm bigger than subaru rotors, so that means the ears are a pub hair longer.
jdmleggy97
Post by jdmleggy97 »
Pads for toyota landcrusier fit and are interchange options for the 4pots. I belive early 90's ,92-94 was the years i think i work in a part store and they were very very close with subtle diffrences.
dscoobydoo
Post by dscoobydoo »
My 4pot/2 pot brakes for the SS are JDM calipers.
I just used 06 WRX pads and they fit fine.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
subytech
Post by subytech »
Tire rack sells pads for "non US Subaru 4 pot calipers" for the 2.5rs.
Or 06-07 WRX TR pads will work
http://www.tirerack.com/brakes/results. ... toModClar=
92 Legacy Turbo, 5sp MT, Early Large CC 20G heads, Ported custom clocked td04, Cobb catted DP, Injen SS 3" exhaust, Turbosmart MBC @ 10psi, Apexi 20g intake, custom FMIC, Fidanza 11lb flywheel, stock 05 WRX clutch
