AWIC with VF-11
drewriviera
AWIC with VF-11
Hey guys, I have toyed with putting an AWIC on my car several times. The last time I did this I couldn't find the hoses to hook it up to my VF-11 and gave up. I even sold it and now I have another. Anyway, has anyone done this with a VF-11? Could anyone tell me the hoses I would need? I do know that siliconeintakes.com has hoses but I don't know which ones to use....any help would be appreciated!
-Andrew
-Andrew
dscoobydoo
drewriviera
Dynamic Entry
you can follow/prompt this thread here
http://bbs.legacycentral.org/viewtopic.php?t=40601
but as he mentions, most every combo has been tried and reviewed - but... most combinations have not been tried and reviewed scientifically (as in by the same person and with the intention of isolating the variables)
part of me is surprised that there is no compendium with the different turbos, their attributes, their results and their support needs
on the other hand, the fact that this type of comprehensive thread does not exist makes sense since theory and attitude differs from person to person and application to application and across different expectations
i have seen people suggest and carry out upgrades to the fuel system (pump, injectors) and engine management (piggy back or standalone or revtronix chip as well as wideband oxygen sensor and a fuel cut defender) for a TD04, and others have run TD05s without any support at all (not even intercooling)
Andrew
16 Outback - wife's daily
95 Gravel Express - Sold
92 Green SVX - RIP
02 WRB WRX - Sold
92 Green SVX - RIP
02 WRB WRX - Sold
Some people want as much bang for their buck ASAP and other people will opt for a little less bang with a much larger safety margin,this would be the first example you gave.There is no getting around the limitations of the stock system,therefor a huge turbo with no supporting modifications will not allow anything other than a different turbo performance within stock limitations - meaning faster or slower spool up,better or worse off boost driveability ect.have seen people suggest and carry out upgrades to the fuel system (pump, injectors) and engine management (piggy back or standalone or revtronix chip as well as wideband oxygen sensor and a fuel cut defender) for a TD04, and others have run TD05s without any support at all (not even intercooling)
Drewriviera: as many have stated here and as my own personal advice,if you want your car to go faster and you dont want to get into a HUGE project then just get a TD04.You can hook up your intercooler,run everything else stock as far as EM and injectors ect. and you will be all set for going bigger and better later on as far as
getting into engine management and whatnot.For now you can just get an MBC and give your car the boost it can handle in stock form.You should be able to up the fun factor of your car a good bit for like $3-$400 bucks.
drewriviera
Im not personally familiar with the AWIC but as far as i know the stock vf-11 turbo is kinda the oddball when it comes to the outlet,so yeah it should be easier if not meant to fit.also I'm assuming the TD04 will hook up to the awic alot easier?
Boostedballs
I have a water intercooler with shurflow pump and heater core + fan with a vf-11. I monitored the intake temp on the engine before installing the intercooler, the temps rose over 180F in 3rd WOT.
My 1/4 mile times dropped over a second when I added ice to the reservoir.
I ran a 15.6 with the ice and boost controlled by ecm.
Now I run 14.1 @ 95mph on a 70hp shot of nitrous.
The vf-11 gets the car off the line like nobody's business but it's the bottleneck at other half of the track. The vf-39 is in the mail to me right now, that should solve that issue.
bummer: I'll have to modify the compressor inlet to a 90deg or some sort of banjo if there's room.
Air-to-Water Intercooler, VF-39, 550 injectors, AEM FIC, stainless race header, 3" stainless exhaust, 75hp Nitrous, 150psi H2O injection, intake mods, stock: long block, 4EAT, ecm.
Shouldnt be any different than what all us td04 guys have to do,just a silicone 90.I also plan on going that vf-39 route eventually,but when i do im going to take the time to modify the intake for under the runner inlet to the turbo like the WRX.I know a couple of people have done it and looks way better.bummer: I'll have to modify the compressor inlet to a 90deg or some sort of banjo if there's room.
I got this info from Josh and should make the awic hookup alot easier. Check out his posts to see the pictures as he does a real nice job on all his projects. The part is a Samco hose kit number TCS-22. I am pretty sure Josh had it hooked up to the vf-11. I haven't done the install on mine so I am not sure, but it looks like it should work.
Jeff
Jeff
drewriviera
I had mine hooked up to the TD05. I didn't bother with the vf11.
The rotated outlet of the vf11 would make it rather difficult to fit it up to the AWIC. I'm sure it can be done, but it's not going to be fun. It's not fun hooking it up on a TD05.
Here's the install pics from my installation
http://main.experiencetherave.com/subaru/images/td05/
http://main.experiencetherave.com/subar ... cradiator/
91legacyawdturbo
Somehow I got the impression that you used it on the vf11 and the td05. Looks like I might start looking for a turbo.
Jeff
Jeff
91legacyawdturbo
well I can personally vouge that the awic is a nice set up. Thou Im running an ej20g with a td04 with an 90 degree inlet tube.
Awic vs air to air tmic allows for a smoother boost and less lag, in my experiences formally ran a tmic off of a 02 and an 06 the awic is better in my opinion but more expensive.
2002 wrx sport wagon
drewriviera
91legacyawdturbo
No, not really. The vf11 outlet points up slightly. The samco is horizontal.drewriviera wrote:Would the Samco tcs22 hose fit up to the vf-11??
drewriviera
Nope, samco doesn't make a hose.
Other option is to do a custom setup.....not too fun in my book.
But also not real hard w/ some silicone elbows and connectors of the right sizes.Legacy777 wrote:Nope, samco doesn't make a hose.
[quote="RJ93SS"]u fail, epicly[/quote][quote="evolutionmovement"]Don't do drugs, kids, men may not need nipples, but we look a lot funnier without them.[/quote]
I just checked to see and the vf11 outlet is smaller that the hose on the tcs22 kit. That means I need a td04 I guess and I would like to go with the jdm version with the 90 degree elbow already on it. If I do that will the rubber 90 degree elbow fit the jdm turbo or is it a different size? And then where do I get the rubber 90 degree elbow that fits the jdm turbo? I would kind of like the oem piece for all the hoses to hook to.
Jeff
Jeff
I have a vf11 with an AWIC. I ended up making an intake with a bunch of silicone peices. Its not pretty, but hey you cant see it under the awic.
I think I ended up using: 1.75" 45deg then 1.75" to 2" then 2" 45deg. It took a good bit of cutting/adjusting/test fitting and it probably leaks, but it works.
Boostedballs
I got my vf39 up and running with a 90deg bend at the inlet. (from a saab or volvo) and it works great. I cut the air box and moved the MAF around. Also, I had to re-clock the compressor (and drill one hole in the WG actuator mount) to get it to point to the intercooler.
There is a little more lag than the vf11 that was in there but not much. The power in the upper RPMs more than make up for the lag.
The BOV sounds WAY different than it did with the VF11. instead of a shhhh, It sounds like SHHH SHHH SHHH!
I'll try to get some photos of it posted.
