Straight answer on intake hoses
Looking for size of hose from stock intake to wrx IC. Is it 2.75 or 3"? What about the 90* hose for the td04 is that one 3" or 2.75" ? Does anyone recall the size of the hose for the PCV that goes from the block to the f-pipe? I am searching but I feel confused and I don't want to order a bunch of parts that don't work!
BSOD2600
Post by BSOD2600 »
In my TMIC installation guide, I documented the different sizes of hoses I used...
'11 WRX Limited
'94 TW | R.I.P.
Ya its a good write up but I am using a TD04 so I need to know what size 90 to use I am reading 65mm or so. so is 2.75" the right size or do I use 3"? Also same goes for between the IC and TB.
RJ93SS
Post by RJ93SS »
i used a 2" id silicone elbow for the td04 to y pipe.
td04 inlet is 2" id as well.
12.7mm is 1/2"
25.4 is 1"
50.8 is 2"
65mm is 2 1/2
76.2 is 3"
101.6 is 4"
http://bbs.legacycentral.org/viewtopic. ... 04+install
You say its 2.5" while in this thread it says 2". Im so confused ah!!!! I want to order these pipes RIGHT NOW!!!!
Inside or outside diameter?
i mean in the thread he said 2.25"
93Leg-c
Post by 93Leg-c »
ericem wrote:Ya its a good write up but I am using a TD04 so I need to know what size 90 to use I am reading 65mm or so. so is 2.75" the right size or do I use 3"? Also same goes for between the IC and TB.
I went out to my garage and measured my td04L sitting there. OD diameter of tdo4 outlet is 2.0", same as inlet pipe going into wrx IC. Wrx IC outlet to throttle body is 2.75" OD.
'94 TW
Perfect thanks! LOL!!
93Leg-c
Post by 93Leg-c »
YW! My pleasure! :D
'94 TW
