2.5 Swap??
2.5 Swap??
does anyone have information or know how to do a 2.5 swap from a newer legacy? I need to run n/a for my class and 2.5 is the max displacement. thanks!
Straight roads are for fast cars, curvy roads are for fast drivers
The easiest way I can think of is this http://www.pms.net.au/03_enginekits.htm#Litre25
Granted it is not the most cost effective, but it may be the easiest.
Robert,
Rio Red 1990 L sedan 5MT at least 302000 mi. and Spruce Pearl 1996 Wagon 4EAT 245000 mi.
georryan wrote:
Don't knock him for thinking outside of the box. At least he has been creative.
the EJ25D dohc will bolt right in, use your sensors if any of the plugs are different. the 2.2 computer will run it, just not at the optimal level.
*sold*
*sold*
There's a post on the Ultimatesubaru.org/forum site for a 2.5 swap HERE....also done for a rally car, I believe.
GL,
Td
GL,
Td
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Re: 2.5 Swap??
wow, thank you for that link! i might be using this soon.
Brad
1991 Subaru Legacy L AWD Wagon 5MT (DD)
2000 Outback 5MT (DD)
2005 AW STi
2010 LGT (hers)
1998 Outback (her DD)
Build Thread
2005 AW STi
2010 LGT (hers)
Build Thread
Re: 2.5 Swap??
http://bbs.legacycentral.org/viewtopic.php?f=9&t=39594
outline of the process i went through
22T5mt items swapped onto phase 1 EJ25D engine
pwer steering pump
alternator
MAF
flywheel cover plate - under-side
22T5mt manifold items swapped onto EJ25D engine
22t throttle body w\c position sensor
22t idle air control valve
22t ignitor
22t purge control solenoid
22T5mt harness modification includes :
extending engine coolant temperature sensor clip to opposite side } on coolant crossover
extending temperature sensor clip to opposite side } on coolant crossover
knock sensor : switching connector style to EJ25D type, to accomidate the knock sensor on 25D
22t crank sensor : switching connector to EJ22t style to accomidate 22t harness
22t cam sensor : switching cam sensor to EJ22t style to accomidate 22t harness
neutral items \ universal fit both harness
injectors 1 2 3 4
oil pressure switch
engine coolant temperature sensor : needs harness extention
EJ25D engine items remain
knock sensor
crank sensor
EJ25D intake manifold items remain
injectors 1 2 3 4
vaccume \ Intake tubing
OTHER PARTS NEEDED TO SWITCH TO EJ25 > 5mt
5mt intake hoses
UN USED PARTS AND SENSORS ON EJ25D > auto
Tourque convertor
EGR valve - i created a false valve gasket and bolted the EGR Valve back on over-top the false gasket with a high temp gasket sealer + capped plumbing
EGR valve solenoid removed + capped plumbing
UN USED PARTS AND SENSORS ON EJ22T-5mt
Charcoal canister removed
Turbo exhaust manifold removed
Extra Parts Involved **
98 GT engine fans
98 GT engine coolant overflow tank
N1446 Brutus
91 Legacy SS 5mt 2.5GT Swap
Re: 2.5 Swap??
N1446 wrote:http://bbs.legacycentral.org/viewtopic.php?f=9&t=39594
pwer steering pump
alternator
MAF
22t ignitor
injectors 1 2 3 4
oil pressure switch
knock sensor
crank sensor
injectors 1 2 3 4
5mt intake hoses
Tourque convertor
98 GT engine fans
Thank you sir!
Brad
2005 AW STi
2010 LGT (hers)
Build Thread
2005 AW STi
2010 LGT (hers)
Build Thread
