Power Window Switches got pushed into door panel...
94LegWagon
So over the last couple of years of owning my car the front passenger and rear drivers side window switches have been pushed through into the door panel. What would be the best way to fix this? Buy new switches and install them or do you think I can salvage the ones that broke? TIA
94 Legacy Wagon N/A 5mt AWD
One of mine pushed into the door panel a couple times. The switch was fine, but the cardboard/fiberglass that makes up the door card was in rough shape.
Some 5 minute epoxy and patience with a popcicle stick took care of it. I reshaped and reinforced the door panel in that area.
94LegWagon
Had a similar issue where the back of the armrest got crunched by the PO. Reshaped it with fiberglass on the inside. Epoxy alone probably would've done the trick.
