i think the title say it all
i am starting to look around and i would like to know which engine i could drop in
Subaru Legacy GT JDM EJ20TT EJ20 Twin Turbo Engine, sti, etc...
btw you must have a look at this legacy lol
http://montreal.kijiji.ca/c-cars-vehicl ... Z171096225
omg this look not so bad on the side view but the rest lol
what engine could i drop in legacy 94 sedan turbo
Have you researched what engine you want? Physically any EJ engine fits, and technically any EJ can be wired up. So you should figure out what you want first.
There are QUITE a few threads on peoples experience with swapping different engines. But the easiest would be the EJ20G for you, just read up on people's swap and build threads.
SubiePrice88
Re: what engine could i drop in legacy 94 sedan turbo
http://bbs.legacycentral.org/viewtopic.php?t=42083
-Jordan
"Nothing Stings Like a Subee"
1993 Legacy Wagon, 5MT, 220k!
impreza_GC8
The stock EJ22T is a pretty capable motor. You could look for JDM EJ20Gs, they can work with little to no modifications to the stock ECU because they are really similar in design.
-'97 Outback - EJ25 block/pistons/HLA heads, EJ22T crank/rods/ECU, EJ20G intake manifold/fuel rails/440cc injectors, VF8 @ 11psi. . . . Fuel cut > me
