94 t leg tranny issue!?
__TT__
Post by __TT__ »
94 t leg wagon
4eat with rebuild at 110,000
currently 198,000 on the clock
pan dropped and filter cleaned around 3000 ago (no filings in filter)
now for the issue. tranny drops out with very little to no grab once it warms up. there is clean fluid in it. when its cold its got good power. this is abrupt, no gradual loss, was not hard on throttle when it went out.
now it could be unrelated but the rad bubbled up on me as well even though my temp guage read normal. also no fan movement.
motor is strong and oil is clean (no coolant)
its been close to 0 degrees all week here in denver.
__TT__
Post by __TT__ »
oh also no cel or tranny codes aside from the duty c which I've known about
94 tleggy wagon, 22t with 2.5 dohc heads, pp6, tdo4, fmic, 3inch catless bpm turbo back, wrx brakes, MANY interior mods to list
Is the duty c solenoid an active code, or just one that gets stored every now and then?
__TT__
Post by __TT__ »
im thinking this is a cooling issue as per my other post.
