Just thought I'd put this pictures up. I had the WL steel endlinks on before for some time now, however I swapped them over to the Impreza to get rid of a clunking I had, and was going to replace the ones on the Legacy.
I found that the new ones were kind of pain to fit in the brackets. I had to trim one of the front links a little to fit into the lower A-arm bracket.
http://main.experiencetherave.com/subar ... eendlinks/
Whiteline Endlinks
Whiteline Endlinks
hey i have been looking at these for a little while ... these are for the 2002 wrx right ?? and they fit our legacys ? with little to no mods to the sway bar or the new endlinks ?
i think im just gona do the front for now .. they are the straight ones right kinda looks like an 8 .
i just wana make sure i order the right parts ! thanks !
jdm jeffrey
photos : http://s135.photobucket.com/albums/q140/jeffreydm28/legacy/
So you had clunking with the figure-8 style links but not the C-style ones you just put on?
What brand are those control arms? How much were they? You can adjust camber with those right?
The fronts are part # KLC20Ajdmellor28 wrote:hey i have been looking at these for a little while ... these are for the 2002 wrx right ?? and they fit our legacys ? with little to no mods to the sway bar or the new endlinks ?
The rears are part # KLC19
The clunking was occuring on the Impreza, not the Legacy. The Impreza had stock endlinks & swaybars. I just replaced the stock endlinks ones with the WL's.kimokalihi wrote:So you had clunking with the figure-8 style links but not the C-style ones you just put on?
They are Whiteline adjustable lateral links. Scroll down a little and you'll find out where I bought them and cost.
http://www.surrealmirage.com/subaru/swa ... suspension
I think price has gone up since I bought them though, and I don't know if ISR is around any more.
As for adjustments....you can adjust anything anywhere on these. They provide near infinite rear alignment adjustments.
I will definately be getting those one day. lol
