pp6 or egreddy when de-tuning ?
N1446
Post by N1446 »
i ve run out of patience running SUPER rich
i m only able to sucessfully drive the car when it is at operating temp
i have a EJ25D running on the original '91 2.2T ECU & MAF and i m swimming in fuel, obviously
i m about to change-out the turbo fuel pump for the N/A fuel pump and also switch the Turbo MAF for an N/A one from either a 2.2 or a 2.5
i m changing the plugs for NGKs as i m not sure what is in there at the moment
i ran a bottle of redline injector cleaner through it and its seems to have settled the idle to the point where it near stalls
.. should i still be using 91 octane or does it matter with no turbo ?
.. is there a way to trick the turbo ECU to only fuel at atmospheric ?
.. should i be looking into engine management, piggypack ECU ?
mmmrrr..
N1446 Brutus
91 Legacy SS 5mt 2.5GT Swap
If you're running a turbo ECU on a non-turbo engine, it's going to be running very rich. piggy back is probably your best bet.
BSOD2600
Post by BSOD2600 »
Without ecu tuning (piggy back, revtronix, etc), the MAF scaling in the ECU is majorly off. The NA MAF has maxes out around 220 g/sec while the turbo MAF maxes out around 155 g/sec -- both are obviously a 0-5V range.
I've got graphs to prove the point if required...
'11 WRX Limited
'94 TW | R.I.P.
N1446
Post by N1446 »
is a pp6 a good start for turning this type of thing ?
the idle oscilates for two-three minutes on cold startup
91 octane seems to calm it down a bit
in the lower range its rough and the car needs to be warm before its managable
i installed new plugs and they seem to help
pp6 or egreddy ? >> going turbo again in the distant future
N1446 Brutus
