more hose questions!!
nicv217
Post by nicv217 »
can someone tell me where hose a,b and c goes. also for the radatior reservor what does the bottom line go to then the other lines on the canister! any info would be great i have trouble with the manual and want to do this one shot...also for the emmissions line that runs from valve cover to valve cover underneath the intake can you put the intake on after that.or is there a certaint order?
A goes to the coolant resevoir
B goes to the IAC valve
C also goes to the coolant resevoir
Not sure exactly what you mean here. Can you please try and ask again.
That plastic emissions line will be zip tied in with the fuel lines and wiring harness on the intake manifold. You'll put it together at one time. The hardest part is getting that center fitting hooked up.
