ICM Question
97imprezaobs
ICM Question
Post by 97imprezaobs »
I have a 1994 legacy touring wagon. i just finished a compete rebuild and when i put the motor back in it started right up...then i did a 5mt swap and the first couple days it started every time. then after sitting a while it stopped getting spark. the ignition relay is good. the fuel pump is priming. i cant figure out why its not getting spark. i started looking into the ICM and while i was looking up the wiring diagrams i noticed that the yellow wire does not have a pin on the Ignitor. it is the same on the two other ignitors i have. and when i test the ignitior connector, the two terminals that are supposed to get voltage when the engine is cranking do not get 12v. anyone have any ideas why?
Re: ICM Question
Any chance you could post the wiring diagram you're talking about? Without seeing what you're seeing it's a little difficult.
