question
turbo_meow
question
Post by turbo_meow »
hey how is it going i am running the tdo4 at about 10 to 12 psi lately it has been boosting to 7 what is some of the things that could be making that boost low (sorry about the spelling) let me know
thanks
Frank
fmic,td04,wideband,3" turbo back exhaust,fuel cut off defence,walbro 255,hks super bov,stock ej22t with 34000 miles all orig.
www.myspace.com/legacyturbo303
www.facebook.com/FrankJoshuaGrasmugg
gijonas
Re: question
Post by gijonas »
Weakened wastegate spring or perhaps ecu in limp mode cutting boost?
turbo_meow
Re: question
what could i do to fix it (first turbo car)
turbo_meow
Re: question
and would the revtronix stage 2 chip help :?:
Re: question
Sounds like it's just hitting wastegate boost. I'd check all your vacuum hoses between the compressor, boost control solenoid, and wastegate actuator.
turbo_meow
Re: question
thank u both um i found it on of the lines had a crack in it but thanks again
Frank :lol:
