add a trubo to 2.5
burgandy outback
add a trubo to 2.5
Post by burgandy outback »
how easy/ hard and what else has to be done? or not to bother thanks, search turned up nada
impreza_GC8
Re: add a trubo to 2.5
Post by impreza_GC8 »
i've got a turbo'ed outback, there is quite a bit of work involved but it can be done. Engine management is always the key, the factory ECU doesn't do well with much boost but I have a friend with a turbo'ed Legacy on the stock ECU using an SAFC to control fuel, he only runs like 6 psi though.
-'97 Outback - EJ25 block/pistons/HLA heads, EJ22T crank/rods/ECU, EJ20G intake manifold/fuel rails/440cc injectors, VF8 @ 11psi. . . . Fuel cut > me
You need to provide more details on what you want to do.
Mattheww044
Post by Mattheww044 »
i want LOTS of power, what do i do? haha just givin you crap.
As stated, it can be done with alot of work. I would personally try to find a SS or WRX motor or something though, ive never been a big fan of just taking an N/A motor and slapping a turbo on there. People do it successfully all of the time, just not something I would do.
wtdash
Post by wtdash »
RS25.com LINK. Deals w/turbo'ing the 2.5 - SOHC (mostly) and DOHC.
Td
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
