I've got a 1995 Subaru Legacy wagon with a cable clutch transmission. Anyway I need to find out for sure what geared transmission is in it 'cause I need to buy one.
Transmission code: 87-TY752VAAAA
I've found 2 different listings for subaru transmissions and one said 4.111 & the other said 3.900. So which one is it?
thanks in advance for the help
						Transmission Gearing question
Re: Transmission Gearing question
The info I have says it should 3.90.  However I'm not sure about that.
If you post or PM your VIN info I can try and check it to see if I can confirm that.
Why are you replacing the transmission?
According to this transmission chartPooparu wrote:Transmission code: 87-TY752VAAAA
TY752VAAAA = US Legacy Outback MY94 = 4.111
'11 WRX Limited
'94 TW | R.I.P.
Here's the page from the 1995 Legacy FSM:
