Nice little write-up over on scoobymods.com
http://www.scoobymods.com/modify-05-sti ... 12527.html
How to modify 05+ STI front struts to fit non-STI cars
Re: How to modify 05+ STI front struts to fit non-STI cars
Perfect, was just gonna buy a 05 STI set-up and this is exactly what I wanted to know, Thanks
Cool. Forgot I made this thread. This one, not the actual write-up lol.
Alright , well I after reading numerous threads I am still somewhat confused in using this set-up on my 92 SS
So basically where Im at is I know that the fronts should just bolt right in up top and after modifying the lower strut mount that it will be GTG.
As for the rears, I would like to know if I can just file out the top holes and use the whole 05 STI unit without having to switch to the 90-91 top hats or camber plates
So what are my best options, Do I just avoid buying this set-up completely and keep searching for a better set-up ?
Does this set-up raise or lower the car ? I have read 2 different outcomes. I plan on running 16x6.5" W/ 205/55's and would prefer to lower it a bit and if I have to get some lower profile tires, So be it.
Any help would be appreciated, Thanks.
Reid.
Reid.
^ Anybody Know
I am running 04 STI struts with 91 rear Legacy strut mounts and 07 STI springs. My ride height is very slightly higher then stock. I believe you can drill out the holes and use the STI rear strut tops, but I haven't done it myself.
92 Legacy Sport
00 Impreza 2.5RS
00 Impreza 2.5RS
Alright, good to know. Might have to shed some spring then
So why did you go with the 07 springs instead of the 04's then, Stiffer rates ?
