Need new tranny options/info?
Have a 91 ss with a 4eat needs new sensors ie speedomotor/odomptor everwhere that ive called quoted me $900-1500... Figured i might as well convert to a manual, which tranny would be a good choice? 02up usdm wrx? Jdm wrx/sti? Soo many options and i dont know much about transmissions, any help/advise would be much appreaciated thanks in advance
Re: Neea new tranny options/info?
05 up LGT 5mt, or 06 up WRX are the stronger 5mt's, if your not planning on making a ton of power a n/a 5mt will work fine if you dont beat the crap out of it....
*sold*
*sold*
No sir the purpose of this one is just to be a commuter whore am looking at the 2011 stis for my "fun" car.
then go buy a trans/diff/driveshaft and pedal box out of a outback wagon.
*sold*
*sold*
Re: Need new tranny options/info?
You sure it's just not the base piece in the trans that needs to be replaced?
http://www.main.experiencetherave.com/s ... lebase.jpg
Well its the speedo/odomotor cable.. Subaru dealerships.quoted me $850-1200
What!! For just the cable? That's BS. The cable is not that much, and you should be able to replace it yourself with a little work.
