Do I need a strut compressor when unbolting strut?
I'm just being safe. The haynes manual didn't say anything about using one, but like I said just bein safe.
90 2.2 N/A legacy awd wagon with outback struts.
Re: Do I need a strut compressor when unbolting strut?
are you just taking the whole strut assembly off the car? are you replacing the whole strut/spring or what are you doing exactly?
Brad
1991 Subaru Legacy L AWD Wagon 5MT (DD)
2000 Outback 5MT (DD)
2005 AW STi
2010 LGT (hers)
1998 Outback (her DD)
Build Thread
2005 AW STi
2010 LGT (hers)
Build Thread
Just unbolting it from the bottom at the knuckle. I've never dealt with struts before, but I'm pretty sure I won't need one Because they're one unit unless I'm gonna take my strut apart. I know this was a dumb question but I just wanted to be safe..
no problem...no compressor is needed. you will be fine if you are just unbolting the strut from the knuckle.
Brad
2005 AW STi
2010 LGT (hers)
Build Thread
2005 AW STi
2010 LGT (hers)
Build Thread
impreza_GC8
You can completely remove the spring/strut assembly from the vehicle as a whole unit without using a compressor.
-'97 Outback - EJ25 block/pistons/HLA heads, EJ22T crank/rods/ECU, EJ20G intake manifold/fuel rails/440cc injectors, VF8 @ 11psi. . . . Fuel cut > me
That's what I thought, thank you
oskar_subaru
just don´t try to take the strut apart without one, u will end up with 12 stitches in your forehead
don´t ask me how i know
1994 Legacy BFB GX 2,2 - 146.000km -
1993 Legacy BF5 GL 2,0 - 512.000km -
