ok so my car is a 1994 2,2 obd1 europe model, and it´s got two lights in the cluster, one says "econ" and the other "power" my owners manual says that if the power light blinks or stays on after turning the car on then there is a problem with the trans, witch it has been doing lately
how can i pull the codes of the TCU ?
Trans codes ?
Trans codes ?
1994 Legacy BFB GX 2,2 - 146.000km -
1993 Legacy BF5 GL 2,0 - 512.000km -
Re: Trans codes ?
Assuming you have a "manual" button you can follow the instructions on my site to pull the codes.
www.surrealmirage.com/subaru/trans.html
Re: Trans codes ?
wow :O that´s awesome
thank´s so much
looks like this has something to do with the small binding i feel when parking, duty solenoid C
thank´s so much
Re: Trans codes ?
Most likely
Re: Trans codes ?
looks like i finally have a reason to install the 5spd d/r i have
