timing belt
timing belt
roughly anyone know how much a timing belt should cost to be replaced? will all new parts and all that jazz?
1993 legacy ss "Shela"
Re: timing belt
About $1000 for a shop to do it, replacing the timing belt, bearing assembly, tensioner, front covers/cam seals...
'11 WRX Limited
'94 TW | R.I.P.
Re: timing belt
bummer, id do it my self but ive never done one before. anyone interested in doing one?
Re: timing belt
Whoa! I never thought that replacing the timing belt would cost that much on a shop. Well, my uncle is planning to bring his vehicle on a workshop to have it replace but knowing that it is quite expensive, I think I'll suggest to my uncle of using a subaru timing belt kit instead and have it replace it ourselves which I think is much cheaper compare to a thousand bucks. Anyway, I'm gonna let my uncle know immediately before he regrets that expensive cost.
Re: timing belt
It's pretty easy, and since the stock EJ22T is non-interferance you won't break stuff if the timing is off, lol.
subaru_styles
Re: timing belt
woa 1k for a timming belt job!BSOD2600 wrote:About $1000 for a shop to do it, replacing the timing belt, bearing assembly, tensioner, front covers/cam seals...
what the shops are you going to?
1994 SS "JDM-OEM"
1992 rhd BF5 gt
1992 rhd BF5 gt
Re: timing belt
Smart Service. It's a long story why I did it...subaru_styles wrote:woa 1k for a timming belt job!BSOD2600 wrote:About $1000 for a shop to do it, replacing the timing belt, bearing assembly, tensioner, front covers/cam seals...?
'11 WRX Limited
'94 TW | R.I.P.
Mattheww044
Re: timing belt
what timing belt "kit" would guys recommend? I'm doing my clutch job soon and am pulling the motor so I can do mounts and other stuff. Have alot of stuff planned.Is there anything else in that "kit" that I should get that isn't included?
Re: timing belt
Timing belts are soo easy on these cars, perfect car to learn on if your a t-belt virgin.
93 Turbo Wagon, 5mt swap, vlsd, sti slanty, vf10, alk, subframe lockout, gr2's, sti sways.
96 F-350 CCLB Powerstroke
89 Volvo 244, lsx swap
