Diagram for Heating/Cooling System
egrier
Post by egrier »
Hi there, I am new to this board, but had great with the Ulitmate Suburu Message Board in getting some rear struts :)
I am looking for a diagram for my heating system. I have heat, blower is working, but windshield defrost is not :(
Please email any info/ideas to me at ejablonski33@gmail.com
Thanks and have a great day,
Elizabeth
Re: Diagram for Heating/Cooling System
Welcome to the BBS Elizabeth!
Does any of your other vent control work? ie. defrost, defrost heat, heat, bi-level, vent, etc?
If not, chances are good that the control unit solder joints are cracked and don't allow proper control of the mode selector. I've got a sticky thread in this forum on this issue.
http://www.bbs.legacycentral.org/viewto ... =10&t=1142
Depending on your skill level, you could replace the HVAC control unit with another one, or try and have the joints soldered.
What year is your Legacy?
Jessekrs123
Post by Jessekrs123 »
Low charge in the A/C system would cause your defrosters to not work properly. I'd check to make sure your system is charged up enough,
2015 Subaru BRZ
1993 Subaru Legacy Sedan 5 Speed FWD Green (EG33 swap in progress)
1984 Subaru BRAT Tan
egrier
Post by egrier »
Just an update.. The defroster's magically started working again and no issues sense then. Only difference is that here is Michigan, the temp warmed up a little for a few days. Possible they were literally froze in that position? Will never know, but glad to have my defrost back in working order :)
