cat converter question
Post by 1-3-2-4 »
I'm trying to figure out where something is not right.. this is a replacement rear cat from bosal and the donut gasket is a dealer part.. now i take it the gasket should slide down on the converter right? it seems like it's too thick to do so by like 2mm..
what should I do?
Re: cat converter question
Is the pipe coming out the converter at an angle? I don't believe it should be like that. You sure you got the correct part?
1-3-2-4
Post by 1-3-2-4 »
don't matter now car is totaled.
it was for a 95 legacy cat to midpipe
That sucks dude....I keep trying to catch up and run across your posts.
What happen to your car....
1-3-2-4
Post by 1-3-2-4 »
car slid over into another lane and a plow truck was going the other way it hit pretty hard..
