Started car other day, "manual" light flashes 16 times then next day CEL stays on
it's still running but hope I didn't mess anything up
Code seems to be for #3 injector... where would this be looking at the engine from the front?
thanks
CEL / Injector #3
CEL / Injector #3
1994 Legacy L "Postal" Wagon w/ an 08/'97 EJ22 NA swap
Re: CEL / Injector #3
Welcome to the BBS. I'd check the TCU as well, because the TCU should not flash if you have an injector problem. Try clearing the codes afterwards and see if the light comes back on. Do you get the same codes in the active mode check with the green connectors?
Standing on front of the car looking at the engine the cylinder's are numbered as such:
Tailights
3 - 4
1 - 2
Headlights
Firing order is 1-3-2-4
Tailights
3 - 4
1 - 2
Headlights
Strange, the next day I go to take it to the import shop and... no CEL and no flashing "Manual" light
Go figure.
*closed*
Go figure.
*closed*
