AAMCO Power Purge
94TurboWagon
AAMCO Power Purge
Post by 94TurboWagon »
Has anyone had this done on there AT. I keep reading bad stuff about it when google searching power purge from AAMCO
95 Svx 75k miles
98 Outback Limited 142k miles
06 LL BEAN 115k miles
wtdash
Re: AAMCO Power Purge
Post by wtdash »
The 'power purge' sounds like a flush to me.
I've read to NOT flush an Automatic transmission if it has over 100K/never been done. It'll loosen up seals that may then start to leak.. It's best to just drain/refill/drive 3x to exchange the fluid.
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Bheinen74
Post by Bheinen74 »
AAMCO will kill that tran.
Do it yourself, drain, measure how much you took out down to the 1/4 cup, refill with same amount of new.
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
I wouldn't go for a machine flush, since it forces fluid through the transmission. However, merely dropping the pan and trying to drain it that way is a waste of time.
Pull the cooler lines, and let the transmission drain itself into a bucket while it takes in fluid on it's own. You won't push seals out that way.
93Leg-c
Post by 93Leg-c »
Dan, just wondering, will the method you described drain and fill the torque converter too? (If this sounds like an ignorant question it's because I am ignorant about ATs. :D )
'94 TW
Eventually it would pull new fluid in. Using Dan's method requires great attention to the transmission fluid supply resevoir that the trans return line is sucking up. If it goes dry, you could cause damage to the trans.
The transmissions should have a check valve that keeps fluid in the torque converter. On some of the older transmissions I've seen the valve wasn't working, and when draining and refilling, I got almost all the fluid out of the trans, which led me to believe the check valve wasn't working.
