Will a 2002-2005 stock boost controller work on a 91 SS
denver427
Post by denver427 »
Found a super cheap stock boost controller off a 2002 wrx was wondering if I could us it to replace the failing stock controller on my 91 Legacy SS.
Thanks for you help!
91 Leggy SS 5spd with; bellmouth 4" to 3" dp, 2.5" bosal exhaust with hiflow cat and twin 3.5" tips, 04 H&R WRX springs on Agx struts with hardened strut tops. :0P
wtdash
Re: Will a 2002-2005 stock boost controller work on a 91 SS
Post by wtdash »
From what I've read - no. Not sure 'why' - probably electronically different, and they have only 2 Vac ports (upper right in pic).
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
denver427
Post by denver427 »
Thanks for the great reply, I love this site!
Just an FYI, the stock boost controller on the turbo legacies is superior to the bleed style boost controllers found on the WRX.
Please check out these threads for more info.
http://bbs.legacycentral.org/viewtopic.php?f=2&t=28297
http://bbs.legacycentral.org/viewtopic.php?f=2&t=45977
