ground points
ground points
been having idle issues i think its related to grounding/electrical issues. what are some good grounds to check that anyone has seen in the past fail or come lose... something idk thanks!!
1993 legacy ss "Shela"
Re: ground points
The ecu ground on the pass strut tower.
93 Turbo Wagon, 5mt swap, vlsd, sti slanty, vf10, alk, subframe lockout, gr2's, sti sways.
96 F-350 CCLB Powerstroke
89 Volvo 244, lsx swap
Re: ground points
No, the ECU ground is on the intake manifold on the back driver's side. There is a bolt and ring terminal there that ties into the engine harness.
Re: ground points
My bad, I was told that by a couple local hardcore subie guys, not sure of their sources tho.Legacy777 wrote:No, the ECU ground is on the intake manifold on the back driver's side. There is a bolt and ring terminal there that ties into the engine harness.
2.2TLegacy
Re: ground points
Not to bump an old thread but I had a question about the grounds on the driver side strut tower. There are 3 grounds, 1 single by itself and then a double ground. I looks like some creature had a chew fest on the double ground connection and chewed through the wires.
My question being, if i wanted to repair them, does it matter what ground wire from the harness goes to what terminal? Or do I need to trace the harness wire to make sure that I am repairing it correctly.
*Note* the loss of ground seems to have no effect on the operation of the car.
'93 Stroker T-Leg - Weisco forged internals, 440cc gray tops, VF39, '06 TMIC, EJ20G heads & intake manifold, EJ25 phase 1 crank, JDM STi 5-speed mated to 4.11 lsd rear end
Re: ground points
No, it doesn't matter which ground wire you connect to which point on the strut tower.
