EJ25 Phase I and Phase II swap info request
07Evolved
Post by 07Evolved »
Ok everyone, so I have quite a question here. Basically, I have a rebuilt Phase I EJ25 with about 2k miles on it out of a 96 outback that I am curious about swapping into a 2000 Outback with a Phase II EJ25...
Is this possible?
If so, is it a straight forward swap? wiring harness? etc?
I have the motor just sitting around and I found a killer deal on a 2000 Outback limited that needs a new engine.
What do you guys think?
Thank you in advance! :mrgreen:
Brad
1991 Subaru Legacy L AWD Wagon 5MT (DD)
2000 Outback 5MT (DD)
2005 AW STi
2010 LGT (hers)
1998 Outback (her DD)
Build Thread
subaru_styles
Re: EJ25 Phase I and Phase II swap info request
Post by subaru_styles »
pretty straight forwad swap. keep the stock wirring. cam trigger timing on the phase1 dohc 2.5 and phase2 sohc 2.5 is the same
1994 SS "JDM-OEM"
1994 gt wagon, next build
1994 turbo wagon
07Evolved
Post by 07Evolved »
sweet...so keep the stock wiring and it should slide in easy as pie?
it doesn't matter if one or the other is dohc or sohc? they are interchangeable?
Brad
2005 AW STi
2010 LGT (hers)
Build Thread
wtdash
Post by wtdash »
No offense, but unless Subar-styles has done this himself, go check out the Ultimatesubaru.org site on this swap.
Phase1>>Phase 2 does have some gotchas - some may be 'show stoppers'. Plus I believe the '00 is MAP-based - not MAF....MAF is same as Legacy's from '90-99>>Wikipedia Link.
You 'could' put the heads from the phase 2 on your phase 1 block, keep the phase2 IM and wiring and you'd be good to go.
Do some more research.....
GL,
TD
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
subaru_styles
i would expect just fabbing the stock sohc manifolds's sensors/wirring to the ej25d manifold would be the easyiest way. as per not having to swap heads.
1994 SS "JDM-OEM"
1994 turbo wagon
