car wotn start
no_one_special
car wotn start
Post by no_one_special »
93 legacy sedan 2.2L at. it wont start. i dont have power to the ignition relay. from the alternator. the didoe is good and has power passing through it. but not very much power passing through it. maybe 1 volt. from the yellow wire to the diode under the dash. the brown connector F50 i am getting close to the same coming out of the other side of the diode.
is this yellow wire coming from the alternator only activated when the alternator turns? i cant get the blet back on yet. and was tryign to start the car without the belt. but it wont start.
Re: car wotn start
The ignition switch is what provides power to the ignition relay. Have you checked it?
no_one_special
Re: car wotn start
the switch is fine. the alternator was out. and not giving secondary power to the relay. i havent put a new alt on yet.
