A/C compressor leaking
mvons
Post by mvons »
We had a mechanic convert to R134 and charge the compressor. It works, but he detects leaking out the back. We bought the wagon and the AC didn't work.
This means we need a new compressor right?
Why is the 1993 compressor so DANG expensive ($500) vs 1994 ($185) or 1992 ($265)
My 1993 half dead sedan turns out has a 1992 model A/C so much for swapping.
The 1993 is 73011AA110 and has a Calsonic label - does that mean it is already a replacement at some time?
1991 2.2L Legacy L 2wd Auto 422k miles - waiting to have head gasket and trannie seal replaced.
RIP 1993 2.2L Legacy L AWD MT Sedan 280K prior abused.
1993 2.2L Legacy L AWD MT Wagon, got at 184k, rebuilding - burnt exhaust valves
Re: A/C compressor leaking
Can you elaborate what you mean by "he detects leaking out of the back"
The part # you listed is not for a Calsonic compressor, but rather a DKKC compressor. If you don't mind listing your VIN, or want to PM your VIN I can look up the parts that are applicable to your car.
Also, just to let you know, you can't buy just the compressor any more, it's a new part # that comes with new hoses to hook up to the condenser & evaporator.
mvons
Post by mvons »
VIN: 4S3BJ6334P6955342
Now you know why I sit confused (car with hubby). I read the part number and read the Calsonic name on it, yet the parts catalog shows it on the dkkc page. So I'll double check it tonight
The 93 sedan was part number 73011AA090 and looked different to the 73011AA110.
The mechanic stated he detected the compressor leaking out the back.
If we need to replace the compressor, are the o-rings dealer only part - assuming we find a compressor used.
I also don't see a part named receiver/dryer. Can you tell I'm confused!
Danny-G
Post by Danny-G »
The reciver/dryer is circled in red, condenser in green, and compresser in blue. Hope this helps. :)
Danny
mvons
Post by mvons »
receiver/dryer is what the parts manual calls liquid tank ay. No wonder why new dealers never got the part right, no one calls things the same!
I got better description - a/c charged and stopped working - because of the leak at the compressor.
And it is a DKKC on wagon So you can't change a DKKC with the other Calsonic which is in my sedan?
Wagon DKKC with the bolts on top
Compared to my bad photo of the Calsonic sedan that we wanted to use until we saw the differences.
The part # 73011AA090 is definitely a Calsonic compressor, while 73011AA110 is a DKKC compressor.
As I think you've figured out, no you can't swap between the two compressors. You can try and find a used compressor to use. From my own personal experience....it'll be hit or miss whether the compressor lasts. I went through my original compressor and one or maybe two additional used compressors before I broke down and bought a new one. I did some research and found out that these compressors (the Calsonic's) are notorious for a common failure on the head end of the compressor, and can not be rebuilt.
As long as the o-rings are in ok shape, you should be able to reuse them. You can try matching them with some in a generic box of AC o-rings.
The receiver/drier you can buy at a parts store. There's not much to them.
Did the mechanic point out where in the "back" the compressor is leaking? Unless it's at a seal point, I would say that having it leak out of the body of the compressor is not very common.
Do you plan to convert the system to r134a or keep it r12?
If so I'd suggest reading over my thread.
http://bbs.legacycentral.org/viewtopic.php?f=11&t=1083
mvons
Post by mvons »
The DKKC has a bolt in the back that is leaking! I see on no part sheet if the bolt is removable and has a seal.
The calsonic 200 # compressor is the same as DKKC except the wire is on the side instead of on top. Oh the things we'll check out taking the DKKC out and playing with the bolt first. Just didn't know if anyone has knowledge of that bolt.
There's probably some form of seal/o-ring. If that's all that is leaking, I'd just try and replace the seal.
mvons
Post by mvons »
Napa had an o-ring that fit, so we'll see. It seems like it is a relief valve, that I assume is not replaceable.
The 200# compressor was the same on top but the brackets below are farther apart. Hoping the o-ring did the job.
