will this timing belt kit work?
lucas
Post by lucas »
1993 legacy ss "Shela"
Re: will this work?
it should work fine
lucas
Re: will this work?
Post by lucas »
is it missing anything?
Rubasu
Re: will this work?
Post by Rubasu »
it looks like it for a N/A with the water pump but all the bearing and belt will work.
90 legacy Wagon LS Special, JDM closed deck 20g, custom 25d heads f/ metic motors, APS GC FMIC, 740cc, VF34, 4.11 F/D, Turboxs RFL blow off valve, now with piggyback.
94 Legacy SS R.I.P (parts car now for 90)
97 Legacy Outback (sold)
lucas
Re: will this work?
Post by lucas »
whats different about the water pump for the turbo cars
Re: will this work?
The turbo pump has some additional fittings and the housing for the thermostat bolts to the side instead of the bottom of the pump.
From the picture that is definitely not a turbo pump. Here's pics of a turbo pump:
http://www.main.experiencetherave.com/s ... P_4741.JPG
http://www.main.experiencetherave.com/s ... P_4742.JPG
http://www.main.experiencetherave.com/s ... P_4743.JPG
http://www.main.experiencetherave.com/s ... P_4988.JPG
lucas
Re: will this work?
Post by lucas »
and that pump will work with all years legacy sport sedans?
Re: will this work?
The pump I have and that is in the picture has the extra port for the oil cooler. If you do not have the oil cooler, there's a different part # for that pump. Or you can use a nipple and clamp to cap off the extra port for the oil cooler.
lucas
Re: will this work?
Post by lucas »
how do i clamp that end off? solder it?
wtdash
Re: will this work?
Post by wtdash »
You need the '92-94 SS/TW EJ22T pump for your '93.
The '91 used the pump w/the extra port to the oil cooler - it's the same pump used on the WRX '02-04 (double-check).
Just get the correct pump for your year so you don't have to mess w/it. The pumps are about the same price, regardless of year.
You should also replace the thermostat and its gasket.
I can personally recommend the 'TheImportexperts' on Ebay.
Plz update your Title, such as 'Will this Timing belt kit work'?
GL,
Td
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Re: will this work?
As Todd mentioned, you're better off getting the correct pump, and what I was referring to was simply a little rubber cap (made to withstand pressure) to go over that port with a clamp.
lucas
Re: will this timing belt kit work?
Post by lucas »
I figure the right pump would be best as well, I was just curious how you'd cap it considering the pressure
It's on the suction side of the pump, so it's lower pressure.
