Just recently did a 5mt swap in my new turbo legacy, I've always preferred the feel of cable clutch trannies with push type pressure plates but I was able to get a full 91 turbo drive train from flywheel to lsd for 300$
I've been driving it for about a week now and HATE the feeling of the hydro/pull type so I figured I would start with removing the clutch damper.
I used
Russell pn: 656222 (20" straight -3 dot approved stainless line)
Russell pn: 641411 (-3 to 10x1 female fitting)
Russell pn: 640471 (-3 to banjo fitting)
My brother works at lordco so I paid 39$ after tax for everything.
The banjo attached to the clutch master, and the female fitting attached to the hard line that goes to the slave.
The 20" is a little long but lets you have lots of room to route the hose.
Outcome? 100% better, nice solid pedal feel from top to bottom and returns smoothly and quickly.
http://performanceparts.com/part/Russell/656222
http://performanceparts.com/part/Russell/641411
http://performanceparts.com/part/Russell/640471
Bypass the clutch damper with part numbers!
bmxkelowna
Re: Bypass the clutch damper with part numbers!
Interesting. Never felt the clutch when it had the damper on it. I removed mine before I got the engine running. I didn't use any parts though. Just used the hose that went to the damper.
bmxkelowna
i didnt even think to check if it was long enough, figured the braided line would be the best (stiffest) option other then hardline.
Oh yeah. If I recall correctly it wasn't actually long enough but with a slight bending of the hard line I was able to connect the two easily.
Yeah, I did not use the damper at all and am very happy with the hydro feel.
Yea was much better without the damper, especially when bleeding it.
2002 Impreza 2.0RS 6MT
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
Man I wish I read these threads before purchasing 2 SS lines, installing it with a new slave. Such a B!tch to
bleed
Got a 15" line, guess i'll remove that POS Damper and try, try again
I Now hate Hydraulic clutches and Power Steering, really miss my bare bones MK1 Jetta more & more, just not the NA FWD
bleed
