Subaru Legacy L Wagon shift linkage on a 91 SS
denver427
Post by denver427 »
Looking for a shorter throw shifter, found a 2000 Subaru Legacy L Wagon Shift linkage was wondering if it will fit my 5spd 91 SS and if it is worth it, having a hard time finding a wrx shift linkage and was hoping to find a cheap alternative. What do you thing?
91 Leggy SS 5spd with; bellmouth 4" to 3" dp, 2.5" bosal exhaust with hiflow cat and twin 3.5" tips, 04 H&R WRX springs on Agx struts with hardened strut tops. :0P
Re: Subaru Legacy L Wagon shift linkage on a 91 SS
The newer legacy linkage should work. As with the WRX linkage you will need to swap out the older style joint and hardware to the newer style.
denver427
Post by denver427 »
So I am clear, I will have to modify the newer legacy linkage as well with that 2 pipes welded together in a + looking peice
Umm....I'm not sure I'm following you.
Does the 2000 Legacy shifter linkage look like this?
http://www.main.experiencetherave.com/s ... /shifters/
If it does, you do not need to modify the shifter linkage.
You do however need to replace the stock joint with this new style joint & bolt.
http://www.main.experiencetherave.com/s ... ages/joint
