older legacy steering column vs 02 wrx
njdriver04
is the spline count and diameter different on the drive shaft end which the steering wheel attaches on the older legacy steering column vs. 02 wrx steering column?
'04 forester XT
Scoob Alumni
'94 TW, '96 L, '00 GT
Scoob Alumni
Re: older legacy steering column vs 02 wrx
I think the steering wheel side is the same based on everyone swapping steering wheels, but can't comment about the side that connects to the steering rack.
njdriver04
thanks for the info
i can say for certain that the older style steering column has less splines than the new wrx styles.
'04 forester XT
Scoob Alumni
Scoob Alumni
oldscoobyturbo
my 93 touring wagon steering wheel fits my 04 forester turbo steering column just fine
i think the other end works too I recall swapping in a 05 impreza TS steering rack and i didn't change the column. I might have changed the u-joint it was a long time ago
Last edited by oldscoobyturbo on Fri Mar 02, 2012 2:14 am, edited 1 time in total.
Silver 99 Legacy GT Wagon
White 90 BC5 RS Type RA
njdriver04
Thanks for the info diesel devil; just want to point out that the 02 wrx rack has a different spline count. I'm curious which steering rack you put in, i assumed the newer styls also had a different spline. I counted 35+1 splines on the 02 wrx steeirng column. The (+1) represents the area where there is no spline on the steering column, i went ahead and measured the span of the area without a spline and then measured the distance between splines and came up with (+1) . I called up Sweet to see if i could source a universal joint that was 36spline and 5/8in. in diameter. they make a single and double universal joint with those specs. im going to install the wrx column in before i decided to go with the single or double.
89-91 steering columns also allow for the use of newer steering wheels?
'04 forester XT
Scoob Alumni
Scoob Alumni
njdriver04
looks like the wrx steering columns is 36 spline 5/8in on both ends
'04 forester XT
Scoob Alumni
Scoob Alumni
02 wrx steering column - check
02 wrx flex joint - check
02 wrx steering rack - check
94 ss steering column - check
94 ss flex joint - check
94 ss steering rack - check
what parts do you want to use? i have all those parts listed above and can mix and match and see what works for you. but i dont know which of the above you currently have or want to swap in. lmk and ill go and check.
OR
i see ur in dirty jersey. if u wanna come by and see if we can make something work lmk.
OR
njdriver04
if you have a wrx dashboard beam, you have my attention.
'04 forester XT
Scoob Alumni
Scoob Alumni
njdriver04
sourced one from a fellow subaru parts hoarder for $50 bucks, thanks though. if you have the wrx 2 pot rear calipers im in the market.
'04 forester XT
Scoob Alumni
Scoob Alumni
njdriver04
has anyone run the wrx dash beam? I have already started formulating some ways to go about doing it. Proven methods would be helpful.
below: legacy on top, 02 wrx on the bottom
'04 forester XT
Scoob Alumni
Scoob Alumni
