AT to MT swap trouble
fngearhead
Post by fngearhead »
So, I have my '95 WRX swap in and hooked up and I'm getting codes 11, 31 and 51. I've been using Josh's write-up http://www.surrealmirage.com/subaru/swa ... #shiftlock. I may have connected the neutral switch wiring wrong, gonna pull my jumper harness apart and check it. I have another turbo ecu, so may plug it in and see if it likes the TPS any better. Also, I was messing around and reconnected the shift lock unit, now my key won't come out. Any easy solution to this?
1989 Cherokee-lifted, locked and beat up
1991 Legacy L 5MT AWD with EJ20G swap SOLD... and rolled :(
1993 Turbo Wagon resurrected with '95 WRX guts
Re: AT to MT swap trouble
You can check the resistance on the TPS to see how it compares to the stock values
http://www.main.experiencetherave.com/s ... sting1.jpg
http://www.main.experiencetherave.com/s ... sting2.jpg
http://www.main.experiencetherave.com/s ... sting3.jpg
Have you tried disconnecting the shift lock again? That should allow the key to be removed, but I've never tried connecting/disconnecting it while the key was in the ignition.
Or you can try this: Look at the bottom of the first scan and top image from the second scan.
http://www.main.experiencetherave.com/s ... ns/065.jpg
http://www.main.experiencetherave.com/s ... ns/066.jpg
