NA parts on turbo legacy work??
skygaze666
Post by skygaze666 »
okay i still cant find a answer to whether i can use non turbo TPS sensor and under intake wire harness on my turbo legacy please please help i need to know bad and i cant find a answer!!!
PhyrraM
Re: NA parts on turbo legacy work??
Post by PhyrraM »
The TPS should be the same if both a first gen cars.
The harness is different, but should be able to be used by repinning a few wires and reusing the grounds from the turbo harness. Or use the non-turbo harness to repair a turbo one by sourcing indevidul wires.
skygaze666
thanks alot man fried my tps sensor and my harness is cracked up and has exposed wires but thanks again
Answered your original post about the harness.
The TPS is the same.
