Gaskets, bearings and seals kits for 22t rebuild question
T-LEGGY
Post by T-LEGGY »
Whats a good set of gaskets, bearings and seals for an ej22t? IM rebuilding it and can't find all that many opinions of what's available. Also I was told metal head gaskets are good idea. Can anyone recommend one? Is Copper or Steel better?
'94 Winestone Turbo Wagon 4.111rLSD JDM 5speed/Rebuilt motor/ A'pexi power intake
randomiam
Re: Gaskets, bearings and seals kits for 22t rebuild questio
Post by randomiam »
Having done a lot of reading, I chose the OEM overhaul gasket set via 1stsubaru parts.. Something like $230? Kit does not come with rings/bearings. For bearings I just used ACL Main & connecting rod race bearings-- Sounded like they have been used without issue in the past.
Subaru-less
T-LEGGY
Post by T-LEGGY »
So the main and rod bearings didn't come with the kit?
T-LEGGY
Post by T-LEGGY »
Oh sorry skipped over that piece of info on my phone. I see it now.
I'll second the OEM gasket kit. it comes with all the little grommets and pieces you need.
Pics of what comes with the kit is on the bottom of the page.
http://www.main.experiencetherave.com/s ... age_02.htm
T-LEGGY
Post by T-LEGGY »
http://www.rpmmachine.com/shop/index.ph ... ail&p=5385
Is this a good kit? Comes with main and rod bearings also and costs about the same as just the OEM gaskets
No idea.....I'd contact them and see if you can find out who makes the gaskets and bearings.
Honestly, I wouldn't put cheap bearings and head gaskets in my engine.
T-LEGGY
Post by T-LEGGY »
Where did you happen to buy your ACL bearings? I came across them on slowboy racing, but I've heard they're somewhat unreliable to deal with. I just bought the OEM gasket set. Just need the bearings and I will be set.
Rubasu
Post by Rubasu »
http://www.google.com/url?sa=t&rct=j&q= ... l8PsEa7WZQ
BAM! this is the place to get your bearings from. last i checked (3 Months ago) they had 18 sets of both.
90 legacy Wagon LS Special, JDM closed deck 20g, custom 25d heads f/ metic motors, APS GC FMIC, 740cc, VF34, 4.11 F/D, Turboxs RFL blow off valve, now with piggyback.
94 Legacy SS R.I.P (parts car now for 90)
97 Legacy Outback (sold)
Rubasu
Post by Rubasu »
5M8297H (for thrust in #3 position) mains
http://www.nolimitmotorsport.com/prod/AEB-5M8297H
4B8296H (suits 52 mm journal size)
http://www.nolimitmotorsport.com/prod/AEB-4B8296H
I'd have to look and see where I bought them from. I bought the race versions which have a slightly stiffer backing I believe. This is my first experience with them, so we'll see how they work.
