dumb question
dumb question
i got the subie running fairly well. well at a idle anyways. when i put it in drive and give it gas it stalls. my neighbor said to unplug the maf sensor and see if it helped. well i tried it and it died as soon as i unplugged it. should it stay running or stall out?
Re: dumb question
it will stall with the maf unplugged.
as for the stalling did you remove or adjust the tps?
Silver 99 Legacy GT Wagon
White 90 BC5 RS Type RA
Re: dumb question
nope the one screw thats holding it in is stripped. and didnt know you could adjust it. the autozone and napa want over 300 for the tps
Re: dumb question
Disconnect the connector from the MAF sensor before you start the car and see if it will run.
You can likely get a used TPS and/or another throttle body with TPS for relatively cheap in the parts shed.
