Here's how the car sat before on the stock suspension:
Here's how it sits now:
Ok, so on to the details of what I did. Found a local guy with a set of KYB Excel shocks for a 2005 Forester XT (not sure if model matters since these were aftermarket replacements) which included the entire front assembly (strut, spring, top hat) and rear strut and spring.
-Front strut/spring/top hat all swapped in as a unit. Easy fitment.
-Rear FOR strut with Legacy spring & top hat. The rear FOR spring is tapered so doesn't work with the legacy top hat, so that's what forced my hand on that rear setup.
I wanted the car a bit higher than before, but I think the front is too high in relation to the rears. Being on not-blown shocks is much better! I also feel like the front is a bit on the soft side now.
Now, from what I've found, the turbo legacy wagon came with 134F/190R spring rates (lengths unknown). With some searching I've found the Forester came with 118F/157R springs, but I don't know if that's from a reputable source...or if the FXT model came with stiffer ones.
I'm setting the car up to be fun on gravel roads and snow, and from my experience, having body roll is actually a good thing as it gives your tires time to take a good set on slippery surfaces. One of the best car's I've played with (on the snow/ice) is a stock suspension 2.5RS. The 2.5RS came with 157F/149R springs, so a set of front springs might do the trick...but I'm not sure if they might be too short to be used in the Forester strut.
So, my question is, does anyone know what the spring heights are between the 05 Forester and 94 Legacy and know what that might do to my front ride height? I can pull stuff apart and play...but just figured someone might just know this off the top of their head and save me the trouble of swapping only to find issues.
Any help appreciated!
