Weird Problem?
Weird Problem?
Well i finally got my car all put back together. New suspension tie rod ends, and the works. When i make a right hand turn it makes an odd grinding noise. I have not gotten an alignment yet, but its only when i make a right. Also when im driving the trans sounds like its grinding possibly any ideas on what to throw in to help squash the sound and maybe make her a little happier? Any ideas on what the grind is thanks. Jack
Re: Weird Problem?
Did you lower it? Maybe a yire is rubbing.
Re: Weird Problem?
kimokalihi wrote:Did you lower it? Maybe a yire is rubbing.
Funny you say that i actually lifted it about 1/2 over stock ride height the car was slammed before both front CV axles where shot like bearings falling out lol, replaced that and thought all was good now this
Re: Weird Problem?
Check for tire clearance on the fenders and all that with the wheels at full lock.
Do you have an auto or manual trans?
Re: Weird Problem?
^+1
Stock tire size? If not, then tires likely rubbing.
Also, if you bought the cheap CV axles they could be bad - I've bought 4 new ones for my Subarus over the years and 2 were bad out of the box....both were el cheapos (hey, I'm a slow learner!).
GL
TD
GL
TD
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Re: Weird Problem?
HAHAHA! I'd rather take my chances with the junkyard or NASIOC for axles.
