4EAT Band adjustment!!
wyomikey
Post by wyomikey »
I know,..i know,..this has been covered on numerous occassions. :shock: My question is to find an easier way to adjust this bugger!! I have a 90' Legacy and i can see the locknut and screw pretty clearly from the engine compartment. Reading the "How to's" it looks pretty involved,...not that i can't do it,.. for just a simple nut and screw!!! I read that if you remove the starter it can be cut out most of the steps,...basically all of them. Is this true on the 90 Legacy's or am i going to have do it the long way. :(
wyomikey
Re: 4EAT Band adjustment!!
Post by wyomikey »
anybody??
You can see a few pictures of where it's located, and I don't think removing the starter would make it any easier.
http://www.surrealmirage.com/subaru/ima ... P_3215.JPG
http://www.surrealmirage.com/subaru/ima ... P_3216.JPG
http://www.surrealmirage.com/subaru/ima ... P_3217.JPG
wyomikey
Post by wyomikey »
I do remember that the guy who did do it the way via the starter had a 98' model. Unfortunately, it does say for models 90'-92' you have to go through unbolting the engine stop,disconnecting @ the Y pipe, crossmember removel,ect....blah,blah,blah. Well,...i did want to inspect my exhaust system anyways,...so i guess i'll make a day of it and just kill two birds with one stone.....
If you have a shorty wrench you can adjust it by feel, and not remove anything. That's what a trans shop did on my car when I was running the automatic trans.
wyomikey
Post by wyomikey »
I did the band adjustment today. I was able to do it the short cut method ,and bypass dropping the tranny ect.... The only things i had to do was disconnect the battery,remove the vacuum booster hose, and unbolt the positive cables from the starter. I used a stubby 17mm combination wrench and an 8mm ratcheting wrench. THe most work,...and it wasn't much, was loosening the locknut. I placed the stubby 17mm (closed end) on the nut ( I don't know if a stubby 17mm ratcheting would work, do to the thickness of the ratcheting end) and used a another wrench, between the tranny for leverage to crack it loose,....no problem. I marked the front face, and a small spot on the top of the adjustment bolt with a white paint marker,and a spot on the tranny as my starting point. I also marked the opposite side of the bolt with a red marker for reference, with some practice i was able to get her adjusted.....i turned it almost 3/4 of a turn counter clockwise. I re-adjusted it one more time after a test drive,the second time it took me less than 10 minutes to disconnect ,re-adjust,and re-connect. She shifts alot better,...i plan to change the fluid next.
Glad to hear that adjusting the brake band worked for you! Let us know if changing the fluid helps too.
Thanks for following up with the results.
