WTB: Sedan Sunroof Assy
As the title says, my motor on my sunroof has seized and it has also started to leak, would rather just replace it with a complete assy if someone has one they are willing to part with.
Thanks guys.
Thanks guys.
'93 Stroker T-Leg - Weisco forged internals, 440cc gray tops, VF39, '06 TMIC, EJ20G heads & intake manifold, EJ25 phase 1 crank, JDM STi 5-speed mated to 4.11 lsd rear end
Re: WTB: Sedan Sunroof Assy
Where at?
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
05 GD-STI
00- GF
Mercer Island/Bellevue area. I know there are some at a few of the junk yards around the state but I would rather give the money to an enthusiast.
Most of us don't pull the whole assembly. I have a few spare glass pieces, but not the assembly. But I know where you can get one.
05 GD-STI
00- GF
05 GD-STI
00- GF
are the sedan and wagon sunroofs different? cause i'm gonna be doing a 94 TW part out come next week, mabe the week after
93 Winestone TW project
Not sure, if any one could verify the compatibility between the TS and TW sunroof assys that would be awesome. Dibs on your sunroof when you start the part out just in case they are the same.
Kk, but it's probably last on the list because rain/ snow lol. And knowing legos, it is probably the same as the sedans lol
The size and weight of one is going to make it expensive to ship.
05 GD-STI
00- GF
05 GD-STI
00- GF
Just for the record, I have a wagon sunroof assembly in my Sedan, the only difference is the 2 mounting holes on the sides (one on each side) don't line up. The corners and front 2 extra holes do line up. I have ran one in my car for a year plus now. Make sure to re-seal the tracts to avoid future leaking.
Don't replace the entire assembly, you don't need to. Just remove it and reseal it, its a really easy and cheap fix. Replacing the motor while your in there is really quick and painless as well. Take a drive down to the 3 junkyards down in kent by the river (binford...and whatever those other two are) and see what they have. Otherwise, affordable auto wrecking right on MLK in south seattle (by the public storage place, right next to i-5) has two legacys with sunroofs. I didn't take the motors out of them, and they should still be there (that guy has had the same cars in that yard for literally years). I did a write up of how to reseal the sunroof.
http://turboleg.com/diy/leak/leak.html
1992 Legacy SS - Auto to 5MT swap and too much of my free time.
