check engine randomly comes on then I have no boost
Whats happening? my check engine will come on a random times, then i wont have boost. then it ill go off, and i have boost again? any ideas? i took it in for the check engine and the guy said there was no codes.
1996 outback sport $6000 worth of mods:Sold.
1992 legacy ss: MBC.. waiting for more.
Re: check engine randomly comes on then I have no boost
Check the stored codes. You can check it yourself.
the guy tried that and nothing happened
Try them again - if your light came on and you lost power then went off you should have a code.
http://legacycentral.org/library/literature/codes.htm
Make sure you are plugging/unplugging the correct connectors.
