Which Replacement Headlight Assembly?
DenCon
Post by DenCon »
All the OEM USDM headlight assemblies out there say the same thing - they're the best.
Which ones are the best - which ones should I avoid?
It's about light output quality - not style.
Of course, I wouldn't turn down a good EDM kit...
rallyak
Re: Which Replacement Headlight Assembly?
Post by rallyak »
Welcome to legacy central,
My somewhat expert opinion working in body shops and do a lot of driving at night. I have used oem and aftermarket headlight and for the most part I haven't seen a great deal in better lighting or quality.
Charles
Welcome to the BBS.
Are you wanting to replace your existing headlights or put in additional lighting?
What year and model do you have?
dscoobydoo
Post by dscoobydoo »
Legacy777 wrote:Welcome to the BBS.
Second this.
But if you have a 91-94 legacy, the Glass EDM headlights just put out a little bit more light to me.
IMHO
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
Apex3
Post by Apex3 »
Where are you seeing options for OEM headlight assemblies?
If you just need a replacement light go to a junkyard, super easy to clean up the lenses to look like new.
EDM lights and/or projector retrofit are your best options for light output. If you mean bulbs then don't bother getting anything fancy, it's a waste.
oldscoobyturbo
Post by oldscoobyturbo »
jdm/edm glass lights are the best with standard bulbs
upgrade with some hid fog lights and you can keep the stock usdm headlights
Silver 99 Legacy GT Wagon
White 90 BC5 RS Type RA
