Turbo vs N/A Flywheel Differences
beaconhillkilla
I have a flywheel from an early model JDM ej20g impreza, will I be able to use this flywheel in conjunction with the N/A transmission from an 06 impreza? Just wanted to find out before I had it resurfaced. It looks exactly the same as the the other N/A flywheels that I've used before.
1992 Legacy SS - Auto to 5MT swap and too much of my free time.
Re: Turbo vs N/A Flywheel Differences
If the flywheel is meant for a turbo trans with the pull clutch setup, then no it shouldn't be compatible with a non-turbo transmission with the push clutch setup.
beaconhillkilla
Okay, thank you
