Gauge Cluster Lighting
DD50
Post by DD50 »
Well I've searched the site and couldn't find anything. I took apart the gauge cluster a month ago and noticed for the shift lights, door open lights, and the hi beam lights it uses tiny bulbs in a rubber casing with two wires attached to the bulb. They come out easily. I don't see why they can't be taken out and replaced with 3mm leds. Since it looks like no one has tried this I'll be the first one to do so. Wish me luck. lol In case this in the wrong spot please someone move it. Thank you
Proud Owner of a 1992 Winestone Mica Subaru Legacy LSi non turbo with 198,000 miles. Soon to be turboed
Re: Gauge Cluster Lighting
Post by SILINC3R »
Sorry man, you're a little late. I have done it on both of my cars. Great little mod when done and makes driving at night awesome again.
Not my car in this thread
here
originalcyn
Post by originalcyn »
Dear god, i've been looking for that specific thread forever. Thanks Tony. By the way, which leds did you end up getting? every time i go to superbrightleds.com or whatever, there's a million million 194 bulbs.
Kijan
1993 Legacy LS | PBM 227
I thought he was talking about the small lights in this thing....rather than the entire gauge cluster?
Post by SILINC3R »
Well than I stand corrected and need to read next time. Josh, I believe you are correct and yes I am not sure anyone has done that.
DD50
Post by DD50 »
Yup Josh is right. Those are the ones I am going to change. That actually helps me a lot since I need to know for sure how many I need
oldscoobyturbo
Post by oldscoobyturbo »
should be simple enough if need be you can add a resistor to the wiring in the back on the harness for that indicator cluster
Silver 99 Legacy GT Wagon
White 90 BC5 RS Type RA
matt00rs25
Post by matt00rs25 »
Is there a bulb list for the cluster so I know how many to order of each?
Post by SILINC3R »
The HVAC controls take two 74 bulbs, the shifter indicator (auto) takes one 194, the cluster takes two 194 bulbs and four 74 bulbs, and the ring around the cigarette lighter takes one 74.
DD50
Post by DD50 »
How do you change out the cigarette lighter ring light? I've been trying to figure out that one too
matt00rs25
Perfect, thanks!!
